Multiview not allowing PS5 and other app?
(Topic created on: 12-04-2024 09:50 PM)
Introvirt
So i have a ps5 and i wanted to be able to make my game small with multiview and grind, while i watch something larger with multiview. However, it seems that my only options for this are my phone, computer or camera, none of which i can use at that moment or are close enough.
ive tried mirroring my iphone but it takes over the whole tv, not only the area its supposed to.
Ive seen in the manual that my options are supposed to be wider, but my menu for multiview seems like its limited? Im up to date, and my tv is the 85 inch samsung tv. Support said it isnt possible to have a game and a second screen open but that just doesnt sound correct, has anyone else had this issue?
 i cant seem to even move over to my console.
2 REPLIES 2
SDcanamgamer
Did you ever figure this out? I cannot do multi view with my ps5 at all. I just get a “This content is not available in Multi view” on the ps5 side
Brad-M2K
I found a fix.
occurse I thought it may be due to all the gaming settings turned that off first. Then it didn’t work still. So I turned off 120hz in settings on ps5
then before I tried again I also turned off auto low latency mode and I turned off HDR because I’m thinking it’s due to the act the tv screen can’t display two entirely different frame rates and HDR etc and the standard had content in same screen etc. but that worked for me
