Model designation 7100 vs 7110
(Topic created on: 22-10-2021 12:28 PM)
MJoy
Hello,
Can anyone tell me the difference between these two tv models?
UE85AU7110KXXU
UE85AU7100KXXU
7110 series vs 7100…
Thanks!
3 REPLIES 3
AndrewL
@MJoy: When models numbers are so similar, the differences are usually cosmetic only, such as a different coloured bezel or stand. Having looked into this for you, the specifications for both models are identical, with the only difference being the AU7110 is currently not in stock on our website. If you'd like to check out the specs for yourself, please follow the links below.
Buy 2021 85 Inch AU7110 UHD 4K Smart TV | Samsung UK
Buy 2021 85 Inch AU7100 UHD 4K Smart TV | Samsung UK
Members_nP0P3J1
I checked up on Costco website.. Apparently the only difference is Lan cable connection..
7100 has it.. 7110 doesn't..
Oscar1968
Solar remote
