18-09-2020 08:30 PM
- Mute
- Highlight
hi all, I have the ue43tu7100, great tv for the bedroom, but i hate the remote contril, its the one with netflix rakuten prime buttons, its too cluttered and way too fiddly when you suffer with Parkinson's
Could anybody suggest a much less clutered simple alternative?
Thanks so much
Solved! Go to Solution.
18-09-2020 08:51 PM
- Mute
- Highlight
Hi @Redmel59 ,
you can control your TV using our SmartThings app, find how to do this here: https://www.samsung.com/uk/tvs/smart-tv/use-your-mobile/
18-09-2020 08:51 PM
- Mute
- Highlight
Hi @Redmel59 ,
18-09-2020 09:44 PM
- Mute
- Highlight
Great suggestion, thanks
19-09-2020 05:05 PM
- Mute
- Highlight
Our pleasure, @Redmel59!
