HW-Q930C Connectivity Issues
(Topic created on: 29-07-2024 05:53 AM)
BrilliantBob
I’ve been having nonstop connectivity issues between my Samsung S95C and HW-Q930C soundbar, via WiFi. Just when I had everything working, it all stopped working just a week later. These are my initial findings:
1) I had to temporarily disable the 5GHz WiFi network on my Eero router to get it setup properly initially.
2) after solving that initial setup headache, soundbar connectivity to the TV failed again when I enabled the more secure WPA3 security protocol on my Eero router. My only options to address it were to either turn off that protocal or hardwire my TV to the soundbar with an HDMI cable.
Anyone else have these issues? Are there any other solutions? I bought this high-end TV/soundbar combination with the hopes that they’d work seamlessly together without any cables. That seems possible, but with a high cost (network security). I don’t want to make that tradeoff…
1 REPLY 1
TonyMcConnell
It’s a great picture on the s95c, perfect viewing angles. But the software on the one connect box is abysmal. Send the items back while you still can and buy an LG instead.
