T5300 RCA Connection Issue
(Topic created on: 27-10-2024 09:50 PM)
Lynny68
Hi all, UPDATE TO ORIGINAL POST: Took the TV back to John Lewis and got a refund. Bought a totally different make/model and everything was set up within 30 mins.
ORIGINAL POST: Just bought the T5300. No matter what configuration I try with RCA cables between my old stack hifi (not bluetooth) and the tv I cannot get any sound from the speakers, there are 2 options -  optical and tv. I have checked the settings, my last Toshiba tv which was only 4 yrs old had a jack socket which i used for the white/yellow ends and plugged the red white into the tv audio sockets, but the Samsung tv doesn't have a jack option. Very frustrated at this point and in desperate need of advice. Thank you
8 REPLIES 8
AustinMc
Voyager
Welcome to the forums, and thanks for your first post! Hopefully, someone here can help with your issue.
Anyway, back to your issue: I'm assuming your hi-fi system doesn't have an optical port and only has RCA?
Fiona26
Samsung Members Star ★
I'm using optical on my TV. The optical lead goes from the TV to dac, then RCA leads plugged into the dac to the Amp. I had to make sure the sound in tv settings was on optical for audio out.
https://www.quora.com/How-do-I-connect-my-new-TV-to-my-old-hi-fi-amplifier
Lynny68
Hi, no it's an old stack hifi with RCA connectors
Lynny68
Hi, no audio port but does have RCA. Tried connecting my sound bar to the TV, but it's not even finding it. The TV is basically rubbish
AustinMc
Voyager
Sorry for the late reply. Is the soundboard Bluetooth?
In regards to the HiFi, I would refer to what Fiona26 mentioned about using a DAC to convert from digital to RCA so you can use the HiFi.
What make and model is your soundbar? I'll do my best to help you troubleshoot. Thanks.
Lynny68
The soundbar is a K2 with subwoofer. I was on the phone to Samsung last night and they couldn't find any way to connect the TV either, it seems there are options not accessible that I need so basically I was sold a tv that does not have the functionality that its advertised as having. Taking it back to John Lewis tonight for a refund
AustinMc
Voyager
Did you arrange a refund? Thanks
Lynny68
Hi, took the TV back as some of the connection settings were greyed out which meant I was never going to be able to connect either my existing speakers or any Bluetooth soundbar. Now have a different make/model TV and everything was connected and working within 30 mins.
