How to wall mount qled 43 inch tv
(Topic created on: 05-10-2020 12:09 PM)
Sidras
How do you wall mount qled 43 inch tv.
I purchased brand new from Samsung and they don't know how to wall mount as the holes in t.v. have no threading. I have m8 screws but can't screw them in the holes. Anyone help??
5 REPLIES 5
TRY2HELP
Helping Hand
all modern smart tv have hole at back for wall mount as far as I know there use m4, m5, m6 and so on, it kinda weird with holes but no thread
TRY2HELP
Helping Hand
does the holes you see have an screw in it, if it have maybe have to remove that screw out first, read the instructions first just incase I was wrong
Sidras
Thanks down the reply. The holes have no screws. Apparently  I need a wall mounting adaptor. But where are they from? Samsung should've provided.
TRY2HELP
Helping Hand
your tv maybe need wire or cable bracket only to hang on wall, you might see like a 2 to 4 nobe at the back to thread a wire through, anyway good luck hope you find a solution
Sidras
Thanks. I will let you know how it goes
