Go to solution Solved
How to setup a Yamaha Sound bar ATS - 1080 to a Q60 Series (50) so.....
(Topic created on: 20-04-2022 08:26 PM)
Russ1
 How to setup a Yamaha Sound bar ATS - 1080 to a Q60 Series (50).
 I set up the TV  to Automatically Search for  the Yamaha Sound bar ATS - 1080 (Bluetooth).
 My question is,
How can i setup - Or Can I setup the Yamaha Sound bar ATS - 1080 (Bluetooth)  to turn off   when I turn off the TV?
Russ1
I still have to MANUALLY turn off the Soundbar.
7 REPLIES 7
Ginga_p
Hotshot
Have you tried connectting the sound bar to the tv in the arc hdmi port on the tv then go to settings and setting to arc
G G
Russ1
I’ll give that a try Ginga P., even though I was L👀king for info on how to do that task using Bluetooth.
Ginga_p
Hotshot
Sorry sir have you tried in the sound settings changing from tv speaker settings to one of the others see if this helps with bluetooth
G G
Russ1
As far as Hooking up the Sound Bar ARC to the HDMI ARC Port yes it does ask Me Quicker if I want to Hear Sound thru the Sound Bar,
BUT the Sound Bar STILL DOES NOT turn off (even though it’s connected in the TV’s Settings) when the TV goes off. 🤷🏻‍♂️
Russ1
(Have you tried connectting the sound bar to the tv in the arc hdmi port on the tv then go to settings and setting to arc)
Yes I have connected the SB in the Arc HDMI port & it still does Not turf off the Sound  Bar when I turn off the  TV.
Russ1
Meant “Turn Off & Not “ turf” off the Sound  Bar.
Russ1
