AppleTV Sound pass though to Optical Output QA65S95DAW
(Topic created on: 25-09-2024 12:23 PM)
Sean__Wong
Hi Samsungers,
Loving the picture quality on the S95D and new Tizen interface.
Need some help understanding how to best set up and troubleshoot Apple TVOS18.0 ( yes the new one) ARC sound pass through to the Optical out put.
Heres the Flow
AppleTV <==HDMI==> SaunsungS95D <--optical-->Yamaha WXA-50
Question
why does this, the simplest of connections and use cases have the need to swap sound models to get some output !
eg
Apple Music  = no sound in Auto / ARC / Atmos
Apple Music  =  sound in Dolby 5.1
Apple TV Movies = Sound in Auto / ARC / Atmos
If any one has a goto guide for this I'd love to know where
Samsung Display Fanboy
Crystal RU 8000
OLED S95D
3 REPLIES 3
Ginga_p
Hotshot
Arc is only possible using a hdmi its a two way signal which a optical cable can not do. Try instead of using a optic to yamaha using a hdmi from the tvs hdmi arc port.
G G
Sean__Wong
Thanks but
Yamaha WXA50 only has optical input no HDMI.
Crystal RU 8000
OLED S95D
Ginga_p
Hotshot
Unfortunately its not possible to pass atmos with a optical cable in the sound settings you will need to use either pcm or dolby
G G
