How to get Sky TV guide since Update 2031?
(Topic created on: 28-11-2024 07:29 PM)
luseferous
As per the title really. Using the smart remote . Used to have to press the '123/RGB' button then navigate to home. Now if I do that I have to navigate through all of the numbers then to another screen to get to the home option
3 REPLIES 3
luseferous
Pressing the channel up/down does nothing.
Piper123
Samsung Members Star ★
Hey there
Would you not be better off asking your question on Sky Community?
S24 Ultra
WGT
I have the same issue after the 2031 TV update. When you press the '123/RGB' you have to navigate through all of the numbers then to another screen to get to the the other options. Use press up/down to navigate to other options.  Use to take like 2 or 3 clicks to get to "Info" option now its like 11 to 12 clicks.  Not very efficient
