How to exit Samsung TV plus ( fix ) ! how to disable samsung ADS. (fix ) How to reset PSID (ads )
(Topic created on: 01-03-2024 04:05 PM)
mikeqc03
lots of complaints about being stuck with Samsung marketing ads for Samsung consumers, don't expect Samsung to give the option to consumer to opt out ! lots of customer returns their samsung product just for that. i have decide to fight,  and keep my samsung tv.!
i have a Qled tv 2019, (superb quality of image )
- to exit SAMSUNG Tv Plus, press on your remote the Back button for 7 or 8 seconds, then release it, just found out last night by mistake )
- you can also put a Parental PIN number, default is 0000, put yours after, then click on all the ratings , movies, tv shows,  and so on., they will become block from viewing.
- to remove ADS.
How to clear your DNS cache on Windows and router.
  1. Open a command prompt (Start Menu, Run, and type CMD)
  2. Type the following command : ipconfig /flushdns.
  3. Empty your browser cache.
  4. Restart your router by leaving it unplugged for 30 seconds to reset its cache.
  5. Done !
click on home, settings, go to terms and privacy, RESET PSID,  personal service Id, and click reset.
click on home, settings, go to terms and privacy- viewing information services ( do not click on AGREE ( leave unchecked ), close .
click on home, settings, go to terms and privacy, Based-interest advertisement, ( do not click on AGREE ( leave unchecked ), close .
go in your router and add AdGuard DNS ( https://adguard-dns.io/en/public-dns.html)
Default servers : 94.140.14.14 or / and secondary dns , 94.140.15.15, click SAVE.
- to disable  samsung tv plus , If you wish to block samsung TV plus , block or ( parental control ) www. samsung.com or samsung.com
- to prevent samsung tv plus from always restarting when turning ON your tv.
click on home, settings, go to general, go to SMART Features, and turn OFF ( remove dot ) uncheck.
- close router, close pc, close your Samsug TV for 5 minutes, and unplug.
restarrt router/wifi, wait 2 minutes, resart pc, and Samsung tv.
no more Hells kitchen ad show on home bar without my will, i am the commander.
have a good day.
mike.
tech support.
1 REPLY 1
jockamainia
Suddenly when switching on TV only Samsung tv plus was all that was available. After trying the advise on line to no avail I checked the channel list and only Samsung tv was there. Went to settings on the tv control and retuned the tv channels. All sorted. The channels are all there plus Samsung tv and can go in and out like normal channels
