I'm new to this Smart TV.
qn900a with Q950A Soundbar. I like the voice controls because I have a disability, so please don't take this post as you think I'm too lazy to use the remote.
What's been happening is I say, "Hi Bixby, Let's watch the Boston Red Sox"
and it will pull up a menu with four different channels. How do I tell it to choose one?
Sometimes I will say, ""Hi Bixby, let's watch channel 925." And it will activate the Comcast DVR and type in the numbers, but very rarely does it actually do the select part. So you see the numbers as if it's typing, but it never presses okay. So I want to tell Bixby to press okay and go to that channel.
How do I do it?
09-01-2022 02:18 PM in
TV09-01-2022 05:46 PM in
TVI really appreciate you taking the time to reply.
I tried your suggestion, and what happens is the channel selector opens for the Comcast DVR, it shows channel 850 or whatever I choose, and then it doesn't select the channel. The channel planner just sits there with the number and nothing happens.
09-01-2022 07:18 PM in
TV09-01-2022 07:23 PM in
TV09-01-2022 07:28 PM in
TVBixby says, "I'm afraid this function is not supported." 😅
09-01-2022 09:01 PM in
TV09-01-2022 09:15 PM in
TVYes I have it enabled. I think if there was a way to control the rate of input, it would fix it. I think Bixby is trying to control it too fast, so the select command never gets executed.
