30-07-2020 10:49 PM - last edited 04-08-2020 03:49 PM
Hi Community,
My TV has horizontal lines that run from one side to the other, from the top to bottom. This is over everything on screen, not just an app or source.
Nothing has been changed however software update 1361 automatically installed the day before.
I have done a full system reset and issue still stands, so hopefully it’s a software issue and not the panel itself as it’s under 4 months old.
Here are the best images of this I could get (from picture test mode):
This is visible from afar, not just up close and sorta ruins everything you’re watching.
Thanks!
14-11-2020 01:36 PM
Hi,
Just got a QE49Q80T last week and when I turned it on yesterday I noticed the same issue you're getting.
Been on live chat to Samsung and they're going to be sending an engineer to look at it. Out of interest, did you get your issue resolved? And, if so, what happened?
Really hoping they're not going to try and claim it's our fault or "it's supposed to be like that" or something!
Thanks!
13-07-2024 03:11 PM
Hi,
have same issue on my Samsung qe50q60. Was your issue resolved? What caused the lines on the screen and what was the fix? Thanks
13-07-2024 03:12 PM
Was your issue resolved? I Have same problem
Thanks
