30-01-2021 06:43 PM in
TVI have a 2019 43 inch Frame, roughly 8 months old, in the same room as I have a small beer fridge.
Whenever the Fridge clicks on or off, it interrupts the TV picture and caused it to go black for roughly 1-2 seconds.
Occasionally, it causes the TV to lose the source it's playing from (in this case, PC).
I usually have to unplug the fridge while in use. I have done some troubleshooting myself.
I initially suspected this to be a voltage drop as I had an older less efficient fridge, but the brand new, far more efficient fridge causes it to happen also.
I also plugged it in in a different room from the same double gang socket next to my main LG TV and it did not cause the issue I have described.
I then left the fridge plugged in downstairs and continued to use my Frame TV upstairs and it still occurs all the while the fridge is plugged in, even from a different room.
I now suspect this to be some sort of EM interference rather than voltage drop. My electrician also has a frame and two fridges and has never heard of/seen this issue before.
Anyone any ideas/suggestions before I contact Samsung direct?
30-01-2021 07:00 PM in
TV30-01-2021 07:34 PM in
TV30-01-2021 11:35 PM in
TVFine. Except I don’t have mine plugged into an aerial at all. I use my computer through that TV.
Come to think of it my house doesn’t even have an aerial. Also doesn’t effect the downstairs TV or the TV that was in that room before.
30-01-2021 11:38 PM in
TV
