Frame TV not switching on / Waking up from sleep with motion setting
(Topic created on: 05-01-2020 12:33 PM)
biscuits99
Hi,
I have set my 43" Frame TV (2019) to sleep after 2 hours of not detecting motion (Night mode is turned off).
It does switch off after that period, but no amount of movement appears to wake it up again.
It has a table underneath it (but at least 50cm of gap between that and the bottom of the TV).
Any ideas why the detection isnt picking up movement? (Its set to high sensitivity).
It turns back on to TV mode once I press the power button on the smart remote.
Thanks for any suggestions.
Tags (4)
7 REPLIES 7
SaudA
Troubleshooter
Hi @biscuits99
Are you still having issues with this? Can you please check if you have the following turned on as well? This will power down your TV after a certain amount of time.
Settings > General > System Manager > Time > Sleep Timer.
biscuits99
Hi,
Yes, I had turned that option off thanks.
I returned my TV and a replacement is working fine.
Thanks.
SaudA
Troubleshooter
Thanks for the update. Glad to hear the replacement is working fine.
Johnspiano
mine is doing the same, the sleep i s NOT on
Steve Luther
I have the same problem with my 3x 32" Frames, once they switch off after no movement or light they never come back on again even after turning the light on and moving around infront of them. So much for motion and light sensors.
ponpisut
I had the same problem until I found out later that the frame 32 doesn't have the motion sensor.
Steve Luther
Well that sucks, I bought 3 of these things purely because of the art option, daylight and movement sensor.
