Frame tv mounting template
(Topic created on: 25-05-2024 11:38 AM)
brixutd
Hi, how can I get hold of a mounting template
Thanks
7 REPLIES 7
DanAhmed
Navigator
Manufacturer's Website: Check the website of the manufacturer of the item you're trying to mount. They often provide downloadable templates in PDF format.
Customer Service: Contact the manufacturer's customer service. They can usually provide a template or direct you to where you can find one.
brixutd
Thank you 😊
DanAhmed
Navigator
Hopefully this helps 🙏
brixutd
Cheers
JimmyP3
Did you ever find this template? I purchased the mounting from Samsung and the installer did a horrible job, didn’t get the Frame centered on my wall and took the template. I need a template so I can fix the problem.
brixutd
I did but the only way was to purchase a new mounting bracket kit, got one off Ebay
FZ1958
But SAMSUNG is the manufacturer. Where can I find the template on this website?
