32” Frame 2022 Wall Mount
(Topic created on: 27-12-2023 05:43 PM)
Scottyhs
Hi Forum heroes.
desperately hoping somebody can help here. I’ve been gifted a 2022 32” Frame TV that I’d like to wall mount but it doesn’t have the brackets to do so and despite searching the internet and speaking to tech support they keep sending me down the route of the slim fit TV wall mount when all I think I need is the two brackets for the top corners to attach direct to the wall.
questions are therefore:
1. is this correct? For a 32” TV can I just get away with the two black wall brackets that I can attach the TV straight onto (available from spares websites)
2. Does anyone know how to get a template - because Samsung don’t……
3. if they don’t work, would the slim fit TV mount be another option?
thanks all and happy holidays!
1 REPLY 1
Gurky
Helping Hand
The 32" doesn't support vesa ao you need the little square looking ones. If you check reviews you'll see them!
