External Amplifier On/Off Power Control with Universal Remote Not Working
(Topic created on: 24-11-2019 08:40 PM)
the_akuma
I've just purchased a new 7 series TV and I've hooked up an external amp, and gone through the Samsung universal remote set up so that it's volume is controlled with the Samsung remote... but the remote will not turn the amplifier on or off.
This is all the more frustrating because the only calibration / test performed when you set up the universal remote is to toggle the power on the amplifier!!!
I did try to get an answer through online chat with a Samsung representative but they told me to:
- Perform a reset of the remote by removing the batteries and pushing all the buttons
- Return the TV as faulty as it's within 28 days of purchase
Has anyone had any luck getting their universal remote to control the power toggle on an external amplifier?
If anyone knows a fix let me know! (and no I'm not returning the TV)
13 REPLIES 13
Horbo
Hi!
Any progress in this matter? I have the same problem here. I managed to configure my Sony amplifier to work with Samsung TV: audio is connected using optical cable, and I can set volume using tv remote. But after I turn on/off TV, aplifier isn't turning off/on at all. Basically I can't find any way to control amplifier's power, but as a step in configuration menu when testing the remote. Amplifier is an old device from Sony TA-FE310R.
the_akuma
I've not had any luck turning the amp on with with the Samsung remote but I've ended up using a Logitech Hub to turn on the amp when I turn on the TV via a Smartthings trigger.
No response from Samsung.
Bundle
Hi I have a similar problem Samsun Q65. Universal remote paired up nicely with Sony SRT DB1070. I could never turn the amplifier on/off with the universal remote, but it did control the volume. However recently it stopped working and I cant really get it to work again. No matter how many times I pair it up again and set up from the begging, the volume control never comes a back.
If anyone has any suggestions, I would be grateful.
Cheers
Derpfy
Same issue here, the only way to power on a device is when pairing the universal remote with it. It's quite absurd, why would it test that in the first place when it doesn't allow to do it afterwards? pathetic
Horbo
After all I use a smart plug (tplink hs100) connected to SmartThings. I configured it in a way when if TV is turned on plug is turned on, and if turned off it's turned off :). Stupid as hell, but it works...
the_akuma
yup, seems crazy but my logitech hub is doing to job admirably with a trigger
Kforce
Just got a 2020 Samsung smart TV, hit the same issue. The TV has all these great universal remote capabilities, and it can power on/off the amp, but it will not do it! Please Samsung, you've built 99.5% of the features, but your missing the last  0.5% to make it useful!  Why??
emrec
It is same for me on 7 series samsung tv and sony amplifier. During setup power toggle works as expected but when I switch on/off the signal from remote controller to amplifier is not being sent. It is a simple bug, samsung please provide a fix for it.
ChadM21
The only way I was able to do it is when you go to new device through universal remote setting choose hooked up through home theater system in
stead of directly to TV. After that I was able to power down the entire system.
