Digital HDTV Antenna for QE55LS03A
(Topic created on: 20-05-2021 09:43 AM)
RedSky3000
Hello
I recently bought an Indoor Aerial for my LS03A. However although it fits into the connection on my One Connect Box. Its not receiving any signal. I was hoping anyone could tell me why and if you had any solution.  Thanks much appreciated.Antenna Connection.jpgAeriel TV.jpgAntenna Connection.jpg
3 REPLIES 3
antikythera
Black Belt
Indoor aerials like that are about as much use as a chocolate fireguard. I tried one and sent it back. It picked up 4 channels and even they were breaking up. You really need a full sized roof or attic aerial
RedSky3000
Its funny because I use the same antenna on my 2014 Samsung 43inch with no issue I think its because that's got a standard HDMI slot and my new LS03 has HDMI2.0.
Back to Amazon.
Take care
antikythera
Black Belt
It's nothing to do with HDMI generations, why are you plugging it into a cable TV socket with some kind of adaptor though? Isn't there a separate terrestrial antenna connector on your one connect?
