QN55Q60CAFXZA Optical and USB audio cutting out ever 2 or 3 seconds with OTA signal
(Topic created on: 10-04-2024 04:18 AM)
wilfsdad
I have outdoor antenna connected to the tv to watch  DTV air channels.
The TV is connected to my nuprime DAC-10 with both optical and usb outputs.
Audio through the tv speaker works fine for DTV air channels, audio through either the USB or optical outputs cuts out momentarily every 2 or 3 seconds.
this does not happen with anything else, only DTV air using the digital outputs.
The tv signal is perfectly fine, i've been using a Tivo bolt for years with no audio glitching, so it isn't weak signal, it isn't the cables it isn't the DAC, since it's only DTV air over digital output.
This is driving me batty.
1 REPLY 1
BrizzleRocker
