02-04-2020 10:44 PM - last edited 02-04-2020 10:45 PM
I have Samsung q60 tv. I have fine bluetooth speakers paired and working fine with that tv. What i find very anoying is that I have to manualy enable it every time i turn the tv on. I takes more than few clicks to set audio to bluetooth device. Every time. I think it might be done somewhere in setting, but I could not find it. If it's not possible, I would call it defect. Still it should be fixable by firmware update.
03-04-2020 09:28 AM - last edited 03-04-2020 09:29 AM
Hi
I have the same issue with my TV UE40MU6400 when i had the samsung soundbar it worked perfecly and did not have tp pair it everytime i siwitched on and off .
But since i changed to a cambridge Audio i do have to pair it every time so i have gone ove to using optical as its under the TV
I think auto connect only works with samsung Sound Bars
03-04-2020 10:04 AM in
So how do we tell Samsung to fix this defect
03-04-2020 11:38 AM in
They wont because as fare as they are concered it works with there products
