Can't control Smart TV volume (on remote or phone) after disconnecting from Bose Bluetooth speaker.
(Topic created on: 08-01-2025 03:13 PM)
CJW96
I can't control my Samsung Smart TV volume (on remote or phone) after disconnecting from the Bose Bluetooth speaker. I have the "not available" notification appear after trying to use my volume controls. I can only fix it by an off/on at the plug socket.
The 'TV speakers' are selected in the sound settings. When I re-connect my Bluetooth speakers, the volume controls work normally on remote/phone.
Thanks for any help!
3 REPLIES 3
Obsydian
Samsung Members Star ★
Hi and welcome, has it ever worked ?
I didn't think Samsung TV work together with non Samsung, Samsung call it Q Symphony but only works with Samsung soundbar and BT Sub and BT Rears.
2 Decades Samsung Ownership, If my response helps leave a Like and Accept as a Solution
DAILY: ZFold6, Watch Ultra, Fit3, CL Ace 2, BT-W6, 20,000 Power bank, Smart Tags
FAMILY: ZFlip5, ZFlip6, Watch6 Classic, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFlip4, ZFlip3, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
CJW96
Hi and thank you for your response!
Yes, it did work. I am using a Bose SoundLink Revolve+ II Bluetooth Speaker as my primary speaker (not conventional I know, but it's doing the job nicely for me) but I occasionally disconnect it to use the internal speakers on the TV (QLED QE32Q50AEUXXU). It worked fine, but now when I disconnect the Bluetooth SmartThings device and switch the sound output to the internal TV speakers - my volume controls cease working on the remote/phone. Simply says "not available"
A hard reset from the sockets will fix the issue, and the volume works again on the remote/SmartThings app, but this isn't a convenient solution. It's weird.
I am not concerned about controlling the TV's internal speakers and external speakers' sound simultaneously or anything. It's just a volume control glitch issue that's causing my aggravation.
Thank you,
eljueta
Hi, I have the same issue as mentioned above, only with some Anker soundcore bluetooth headphones. Same exact issue, lost tv speaker volume control after disconnecting the speakers. TV is a 55Q74A. Thanks to the OP for the disconnecting from the socket tip, I was going mad trying to solve the issue.
