Channel scan doesn't fine freeview channels
(Topic created on: 17-04-2020 10:04 AM)
Orm_lea3
Hi I have just moved house and since doing so when trying to retune my TV it isn't finding and freeview channels, only TV+. I've tried everything I can't think of including all the settings, a factory reset even turning it off and on again! Any advice would be appreciated.
4 REPLIES 4
AsadM
Hi @Orm_lea3. Hope you're doing well. Are you using the same aerial on the TV you were using at your last address? If not, have you checked if there's a signal being broadcasted via the aerial? Also, what's the model of your TV?
Orm_lea3
Hi and the same to you!
The aerial is brand new but it is definitely giving out a signal, when resetting the TV it confirmed that. The model number is: UE50NU7020K. Hope this helps!
TessM
Mastermind
It does! Has this been working previously? If so, take a look at page 97 in this manual to search for channels. If this doesn't work, check that the aerial is connected correctly and/or try this cable with a different device to see if this is still happening.
Nitinv1
Hi,
I am having a similiar sort of issue however i don't get the option to click on the auto scan.
It is a brand new tv the Q95 i have everything connected antenna, power cable etc not sure what am doing wrong.
Can anyone help?
