Go to solution Solved
changing tuner localization on D7000 series
(Topic created on: 16-12-2021 09:37 AM)
bebho
Hi, I bought a UE46D7000 TV with a tuner set to France localization, I need now to tune channels in Italy, how can I change the tuner localization from France to Italy ?
Tags (2)
Pugs1957
SuperStar
The tuner in the set is calibrated for French TV so unless it can be flashed ot the tuner is replaced, which I don't know is even possible, you won't be able to rectify the issue. Flashing may not work, anyway.
4 REPLIES 4
xSteveuk
Samsung Members Star ★
bebho
Unfortunately it doesn't help because the TV already perform the auto tuning but at the end the channel numbers are not ordered following the country numbering (Italy in this case).
Pugs1957
SuperStar
AndrewL
@bebho: This may be possible by heading to Menu > Channel > Enter, and exploring the Antenna and Country options. For further clarification, please check out pages 26 and 27 of the user manual via the link below.
01_ENG_GPDVBEUA-0106.pdf (samsung.com)
