Samsung TV flickers in and out when using switch dock.
(Topic created on: 31-01-2023 05:54 AM)
Ghost173
I have a QN65Q60 TV. The TV is supposedly capable of supporting Full RGB.
Yet, I get a constant blacking or flickering of my screen when I set my docked Nintendo switch to full RGB. Interestingly, during Fire emblem cut scenes the issue stops, but during gameplay it flickers. It appears as if the TV keeps dropping the signal.
Has anyone found a way to use the Nintendo switch dock on full RGB with a Samsung Q series. I know that there are similar threads on this flickering issue that suggest simply setting the Switch’s RGB to limited, but sacrificing picture quality seems like a bad compromise rather than a fix. I know the switch and cables function fine on other screens, just not on my Samsung.
Simply asking if changing RGB settings to limited,  fixed the problem? Does not fix the problem.
0 REPLIES 0
