Can I connect a Samsung wireless sub woofer to the TV qe55qn95a.
(Topic created on: 20-08-2021 11:28 AM)
gman21
My soundbar might be on the way out (hdmi earc connection intermittant) and the new TV doesn't sound too bad. The addition of my existing sub woofer may negate the need to buy a new soundbar if I can get it connected to the TV. (The wireless connection to the soundbar and woofer still works ok at the moment). Any ideas?
1 REPLY 1
AndrewL
@gman21: I'm not sure about this. If the subwoofer came with the soundbar, and connects wirelessly to the soundbar, or via a hub, then it's not likely to connect directly to the TV. If it is possible, it can be done via Settings > Sound > Sound Output > Bluetooth Speaker List.
