Both TVS turn on and off at the same time using one remote
(Topic created on: 10-07-2022 08:54 PM)
HB266
Hi both Samsung TVs in our living area turn on and off at the same time when using our Samsung smart remotes and our Sky remote
Model nos AU800060
UE50Tu8500
Is there a fix for this please
7 REPLIES 7
Troubadour
Pioneer
Something to try. If your remote relies on wi-fi setup. Modem/routers often have a guest wifi network. Try setting one up on the guest network. This might allow the use of one network for one remote and the other network on the other remote.
Another thing to try. Turn off one tv and remove the batteries from the remote. Pair the working tv and its remote. Now turn off that tv and remove the batteries on that remote and turn on the other tv, insert the batteries on the second remote and pair them. Now turn on both tvs and add batteries. Test.
Obsydian
Samsung Members Star ★★
It's the IR blaster, it usually needs line of sight to the TV.
I have the same issue with TV and Monitor.
2 Decades Samsung Ownership, Follow me on Instagram Obsydian_SMS
DAILY:  ZFold7, Watch Ultra, Fit3, Buds2 Pro, CL Ace 2, BT-W6, 20,000 PB, Smart Tags
FAMILY: ZFlip7, ZFlip6, Watch8, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFold6, ZFlip5, ZFlip4, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
Renato1223
What was your solution? I have a smart TV and an m8 smart monitor in the same room and the controls interfere with each other its annoying. Lmk if you found a solution. Contemplating on buying a 3rd party control for the TV only.
HB266
Manually turn off at Tv
JamesGniadek
Did that work? Love to know which you purchased
DrHellike
any solution? Same issue here, Smart TV + m8 monitor.. both remote controls are controlling both devices..
Frostymj
The smartthings app switches each tv on or off individually.
