27-03-2022 02:40 PM
When I connect the bose speaker via hdmi to the earc port on the TV it says " audio device is connected to a port that does not support earc" but it is connected to the earc port !
Annoying
Thanks
Colin
27-03-2022 03:19 PM
@Ccstew: Please can you confirm the model number of your TV, located on the sticker on the back of the device, or in Settings > Support > About This TV? In the meantime, please ensure that you have the HDMI cable connected to the eARC port on both the soundbar and TV.
27-03-2022
04:27 PM
- last edited
27-03-2022
04:55 PM
by
AndrewL
Hi Andrew
Model code QE85QN85AATXXU
Hdmi cable connected to bose speaker and earc port on tv
Thanks colin
I seem to find this community site difficult to navigate maybe its me
27-03-2022 04:28 PM
Bose speaker says hdmi arc not earc could that be a problem ?
27-03-2022 05:03 PM
@Ccstew: Potentially, however you may wish to reach out to Bose for further clarification. What I'd suggest is trying an HDMI 2.1 cable for ARC to eARC, or connecting via a standard HDMI port to avoid any potential compatibility issues. Depending on the Bose connection options, you may also wish to try connecting via Optical cable to see if this helps.
27-03-2022 06:30 PM
