AU7100 65 inch TV VESA screws don’t fit
(Topic created on: 02-06-2022 12:30 PM)
Cuke
Trying to wall mount my new Samsung AU7100 and all of the screws in the wall mount don’t seem to fit…
The TV guide in the box is pretty unhelpful, just says to use M8 screws and the screws that came with the mount are apparently M8.. But they are too narrow and just spin in the hole without screwing in… Cant seem to find any info online about Samsung using weird non standard screws but can’t think what else is can be….
2 REPLIES 2
potatodog12334
Maby if you try and find m8 screws of the same length and see if they work
BrianL926
Just wondering if you got anywhere with this, I have the same issue. Instruction state it should be M8, M8 Bolts/ Screws aren't broad enough for it, M10's are too broad, M9's are like hens teeth to get.
Most universal stands seem to take up to M8's. Seems madness but I could be returning a perfectly usable TV because it's incompatible with stands/ wall mounts.
