Go to solution Solved
Add to home feature not working
(Topic created on: 18-02-2020 10:45 PM)
Kewo123
Today my smart hub apps launcher lost the apps I had there, so I went to settings to add it back as shown in this video at 0:47 https://youtu.be/6wndUMdfoNw. But in those settings it says the app is already added to home so I can't add it anymore, however it's not there and it's quite frustrating. Anybody know a solution to this problem? Thank you
EMS88
Cold Reboot the tv using your remote, just hold the power button down until the tv turns off and back on again (5 seconds) without letting go of the button. As the tv turns on and everything loads back up you apps should all appear like normal.
9 REPLIES 9
ChrisM
SuperStar
Hi @Kewo123
Did you manage to get this resolved or are you still having the same issue?
Kewo123
The issue has resolved on its own, I didn't manage to do anything manually but after about 24 hours the buttons appeared on my home appl launcher again. Probably just a glitch.
CadKel07
Hi Chris, I am now experiencing this issue and have reset both the SmartHub and the TV itself and gone fully through the reset, it is just telling me that the apps are already added but they are not on my home screen.  Any advice?  Thanks!
EMS88
Members_mBCyRWE
This worked on a treat much appreciated.
AlexRoc
Hi, I have the same issue, but the option of Cold Reboot doesn't change anything. I want to add apps to my home screen when I try I have a message saying "This app has already been added to the Home screen" but it is not.
P77S
Cold reboot didn't work.. I even unplugged the tv .. resetting smart hub would require logging in / downloading all the apps right? Anything else before I do that?
P77S
Nope didn't resolve on its own.. netflix still not showing
Nternet7
Same problem with me. Samsung needs to fix this. It’s not anything we did or really need to waste our time adding these apps back.
