Add Disable Autorun Multiview Mirroring for QA65QN90A
(Topic created on: 23-07-2023 09:45 AM)
Carl Jenke
Hi,
I’ve seen for newer models there is an option to Disable Autorun Multiview Mirroring as well as Casting. Currently on software 2130.8 (latest) there isn’t this support. Will this option become available for earlier models?
5 REPLIES 5
AndrewL
@Carl Jenke: It should be possible to disable this feature by heading to Home > Settings > General > Smart Features > Autorun Multi View Casting, and press Select to enable/disable.
Carl Jenke
Thanks but Casting and Mirroring are different and turning of casting has no affected on airplay from iPhone or Mac, still auto runs Multiview regardless. Here is a screenshot of the newer models settings found online showing the different between casting and mirroring.
LukeB2
Helping Hand
Could you show me what you are able to see on your TV, @Carl Jenke ?
Carl Jenke
LukeB2
Helping Hand
This appears to be available for 2022 models only, @Carl Jenke .
