I was signed up for this countdown, in case anyone hasn't seen it, MORE TVs !!!
Liking Generative AI wallpapers, 8K upscaling, and glare-free... View Post
2024 Neo QLED/QLED :Update version 1106.9 - June 2024
Improved HDR image supportKids Mode and Small Window Playback optimizedNew font in the... View Post
I need to get contact details for a repair to a TV. It has developed a fault where the screen will not come on. I can see the backlight working and... View Post
Hi, I need to connect an externat speaker without cable and i ordered a BT speaker but, even if I find it in the bt list when I tri to connect it... View Post
Samsung TV update #1401 caused ALEX TV App to stop playing movies and trailers. I have tried all recommended fixes. Only a hard reset without... View Post
Hi! I've just bought a Samsung Smart TV and I’d like to control it using the SmartThings app, but I’m not sure how to add it.
Could someone... View Post
Hi,
I recently did a hard re-set on my fire-stick because of various issues that I
was having. When I turned it on the fire-stick, the home... View Post
Hi,
I have 2021 QN55QN90A. When navigating to settings to reset - I'm looking to do a full reset of the TV. A pin is required when it pops up... View Post
Hey all. Is there a way to disable the “Now Playing” screen on the Tizen home screen? I’m not a fan of having the content continually playing... View Post
As the legs are now too big for my new bedside table, I brought a universal Table top stand .As recommended I purchased M4 28 mm pan screws but... View Post
My 5+ year old just started to default to some Korean rom/com channel I never watch (only know 2 words Samsung and one cant replete here) it ... View Post
Just purchased a S95F 55" TV. When trying to connect to WiFi 7 access point, it fails to connect after trying to connect to the correct SSID,... View Post
Hello,
I finished to install my new TV 75QN990F,but no way to use the remote control of the Tv with my formuler Z11.
It was ok before with my... View Post
Hi,
I have a QE43QN90DATXXN smart tv with firmware 1301, and I can't use the Prime app anymore. This happend all of a sudden about a month... View Post
