04-10-2018 10:49 PM in
TVUEM55MU6120
unable to use Equalizer regardless of source! Tried hold standby for 10 seconds and no difference, still greyed out!
Help! I need some Bass in my life!
Solved! Go to Solution.
05-10-2018 11:37 AM in
TVHi @Drakisath.
Let's try resetting the sound first of all. Go to Home > Settings > Sound > Expert Settings > Reset Sound.
Let us know if this helps.
TVHi @Drakisath.
04-06-2019 08:40 AM in
TVNot sure if it worked for them, but it did for me! Thanks!
14-05-2020 09:57 PM in
TVHi, I have reset the sound but still no equaliser ?
15-05-2020 12:53 PM in
TVMine is also still greyed out, using HDMI inputs only, can someone confirm if equalizer is supposed to be available on all inputs?
14-07-2020 08:12 PM in
TVI have a one week old 2019 Q80R 65" and I cannot access EQ in Expert mode. I have tried with TV speakers only and with a soundbar connected through HDMI arc, but still no access Equalizer.
Treble is too low and I would like to raise. 😔
26-10-2020 03:30 PM in
TV18-11-2020 10:39 PM in
TVI have the same model with a Samsung soundbar. Out of the box the sound is really terrible, sounds like an AM radio.
Tried Optical connection and the equaliser remained greyed out. Switched to a bluetooth connection, reset the sound and suddenly I was able to improve the sound using the equaliser.
Still, sound via soundbar is surprisingly low quality tbh.
09-10-2022 01:02 AM in
TVAlso could try turning amplify off under sound mode.
