25-12-2021 03:14 PM in
TV#QN65LS03AAF 2021 the frame switches from optical to TV speaker at random. I have an older Panasonic receiver that is functioning perfectly. It doesn't have EARC or HDMI just optical in. The TV will randomly switch from digital optical out to TV speaker or the remote will just unpair from my receiver. Why is it so hard for this TV to remember its settings?
25-12-2021 03:35 PM in
TV06-01-2022 02:20 AM in
TVThis did not fix the problem
15-01-2022 10:13 PM in
TVUpdate: The TV has now started doing it mid-program. It will flash the a message about setting up the remote (which is already set up ) I will hear a high pitched whine (just on the edge of my range) and then the tv will say setup failed and for me to set up everything all over again if I want to use the remote. This is incredibly frustrating.
20-01-2022 07:41 PM in
TVI have the same problem.
My Samsung soundbar uses optical in only. It's set up as home theater on the TV. It works well... The last couple of months it keeps switching back to TV speaker.
I wonder if it is a dodgy firmware upgrade.
21-01-2022 08:09 PM in
TVI may have fixed the issue. I forgot that my Chromecast TV had the soundbar set up, I think the TV and the Chromecast were fighting over the soundbar.
Kinda weird though because the symptoms didn't show up until a month ago.
Consider this resolved at my end unless I report back.
21-01-2022 08:11 PM in
TVOh and I forgot to say, I deleted the soundbar from the Chromecast TV settings.
22-01-2022 01:57 AM in
TVunfortunately not a solution for me. Are you experiencing the high pitched whine when the tv decides to switch to TV sound?
25-01-2022 01:03 PM in
TVI have disconnected all HDMI cords from the tv and I'm still having issues with the tv switching to TV speaker. I haven't witnessed it mid program yet but it is still happening
28-01-2022 02:40 PM in
TVWell I thought my issue is resolved but it is not. Problem persists.
If you are getting a nice (I'm not) try changing digital output setting to PCM (not auto).
