2018 55 Q9FN Dolby Atmos
(Topic created on: 23-06-2019 12:44 AM)
jamief
So looking at a soundbar which has dolby atmos sound so wonder if tv supports dolby atmos sound. The bar will  be plugged in via arc
7 REPLIES 7
AndrewL
@jamief: This model features Dolby Digital Plus and can be activated by going to Settings > Sound > Expert Settings > Digital Output Audio Format > Dolby Digital Plus, and is only available via HDMI ARC. Hope this helps.
Krashing
Navigator
Hello please check this petition to bring Dolby atoms and vision support on our high end tv http://chng.it/ZTTsbD46TF
Krashing
Navigator
AdyB
Even though I have a Sonos Arc plugged into my 2018 55Q9FN, I only get the option of PCM and when I select Dolby Digital Plus I get "This Function Isn't Available". Why is that and when will Samsung give us the ability to fully use Dolby Atmos without having to upgrade to a brand new TV? Will Samsung release a new 'One Connect Box' for this model to be able to take advantage of Dolby Atmos?
DanielG1
I have also Q9FN (2018) Model.
I wanted to get the sonos arc.
Did you try to start playing atmos material via apple TV or oder HDMI inputs and then check if DD+ ist? selectable ?
I believe that the samsung apps are not updated for Atmos content, but maybe via HDMI pass though the atmos audio content can be send  over DD+ .
Thank you for some feedback.
Krashing
Navigator
Yes I tried
it doesn’t work. The only way to get atmos on q9f is to connect the media player directly to the sound bar otherwise it doesn’t process it
MikeMagnum
How do we do that and what's the most affordable option please?
