13-07-2020 03:13 PM
- Mute
- Highlight
Hi - on my Samsung QLED TV, I thought I'd try Standard mode rather than Movie. In Standard, I find my 20 point settings greyed out. Is this correct?
Thanks.....
Solved! Go to Solution.
13-07-2020 10:58 PM - last edited 14-07-2020 10:36 PM
- Mute
- Highlight
Thanks.....
Hi @StevenLyall yes I take it you mean the White Balance Settings, which adjusts the colour of the image. in Standard Mode you only have the 2 point settings, whilst the Movie Mode has the 2 point and 20 point settings.
Whilst you can change these settings , you may not get clear result adjusting manually and experts generally recommend keeping it at default if not using specialised equipment.
See more here https://www.rtings.com/tv/learn/how-to-calibrate-your-tv
- Mute
- Highlight
Thanks.....
14-07-2020 07:33 AM
- Mute
- Highlight
Many thanks - very helpful.....
