Go to solution Solved
Power on and off using a mouse
(Topic created on: 03-05-2017 07:39 AM)
bxgti4x4
I use a Samsung mouse to control my tablet but I cannot find a way of shutting down using the mouse.  I have to press the Power button manually to bring up the dialog box, after which I can use the mouse to select the option.  Can anyone tell me how to use a mouse action to bring up the Power Off dialog box.
Thanks a lot
John
ChrisM
SuperStar
Hi @bxgti4x4.
You're not able to bring up the 'Power Off' menu without physically pressing the power button we're afraid. Hope this helps.
1 REPLY 1
ChrisM
SuperStar
Hi @bxgti4x4.
