Smarttag2 - Issues, avoid low power mode
(Topic created on: 20-09-2025 02:08 PM)
Obsydian
Samsung Members Star ★★
So I thought it would be a good idea to put two of my Smarttag2 into power save mode, only to realise aside from a location within 50m, I have no way to locate, ring or reset them.
So I tried to reset from my account, which has now caused a bigger issue of its now nit mine and saying its registered to another account ???
Couldn't reset them, via Smartthings
Reset them manually and no its says they are registered to someone else ???
2 Decades Samsung Ownership, Follow me on Instagram Obsydian_SMS
DAILY:  ZFold7, Watch Ultra, Fit3, Buds2 Pro, CL Ace 2, BT-W6, 20,000 PB, Smart Tags
FAMILY: ZFlip7, ZFlip6, Watch8, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFold6, ZFlip5, ZFlip4, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
15 REPLIES 15
Tourbillon De La Vie
Take out battery?
Obsydian
Yep, and a few resets 🙏
Star_girl
Mine work, I can locate them in real time even when they are in low power mode. They don't let me track them, but I still can find where they are. I love my Smart Tags 2. Maybe yours are faulty?
arianwen27
Did turning power save mode off not work?
It kinda looks like normal behaviour to me. Low power mode makes them only appear on the map. To track them with signal and stuff, you toggle power save mode off first
Obsydian
I can find them, but only to the 50 metres minimum, low power mode turns off BLE and the Ring function
Obsydian
Did not work as would nit connect via BLE
Star_girl
Star_girl
Mine appear on the GPS no matter what.
arianwen27
Strange, power save mode doesn't disable BLE, it just stops the close find features from working. Meaning UWB and Bluetooth distance tracking. Though it does disconnect your phone from having a constant connection with the tracker, only connecting when needed.
If you have 2 trackers set as "notify when left behind" then try to change settings on a power save mode tracker, it can take maybe a minute to connect.
You probably just encountered Bluetooth being funky and coincidentally power save mode was on. Since that mode makes your phone reconnect a lot
