SmartTag 2 - Battery life and low warnings ⚠️
(Topic created on: 21-02-2025 02:38 PM)
Obsydian
Samsung Members Star ★★
I used to keep a log of how long my SmartTag CR2032 battles would last, but gave up as thought 5 mths was ok, but in the last 6 mths I have purchased two 10 packs from Costco, Duracell, so it's gone downhill, a few i set to power save mode, but what's the point of a SmartTag without the Smart bit.
Also finding it am getting daily reminders for 4 of my SmartTags, but when I go into the app, connect and check it shows as fine.
Anyone have battery life and low battery warning issues ?
2 Decades Samsung Ownership, Follow me on Instagram Obsydian_SMS
DAILY:  ZFold7, Watch Ultra, Fit3, Buds2 Pro, CL Ace 2, BT-W6, 20,000 PB, Smart Tags
FAMILY: ZFlip7, ZFlip6, Watch8, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFold6, ZFlip5, ZFlip4, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
9 REPLIES 9
-Robot-
I have the same issue, theybdont last long double battery life if you powe save but typically use energiser batteries
GusB
I did have a bad run with some battery packs but more recently have been ok.
**Photography IG: @slappa_da_tubs | Travel Vlogs YT: GusBan Travels **
Obsydian
I think SmartTags should be rechargeable
Martinkda
Pathfinder
My smart tag battery drains soooo fast, no clue why as they are just on my keys etc but I don't get battery low warnings even though the battery level is very low. I put a battery in one of them and 3 weeks later it was down 50%.
Ferenc75
@Obsydian 100% agreed
bnb90
Navigator
I have just bought some SmartTag 2's. Constantly getting battery low warnings but the battery is fine in the app.
Beta22
Voyager
I'm getting the same constant low battery warning when its actually "sufficient" in SmartThings. Sounds like a bug.
Obsydian
Excellent thanks all, it seems to be once the tag connects via the app the battery level is fine, but getting daily reminders they are low, might get a volt meter
GoanGeek
Blame it on the cold weather.
I got for my car one.
Duracell as well. 😊
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
