Easy Connect Audio Issues
(Topic created on: 15-11-2024 02:16 PM)
Jakub3639
When trying to use samsung easy connect, from a Windows PC to a 2023 samsung TV, there is little-to-no audio. Whenever there is audio it is very delayed and pretty much just static noise.
Anyone else experience this?
1 REPLY 1
Error1245
Pathfinder
Try some of these troubleshooting steps:
- Update Drivers: Make sure that your PC’s audio drivers are up to date.
- Use HDMI Cable: If possible, try using an HDMI cable instead of a wireless connection for better audio quality.
- Check Network Connection: Ensure both your PC and TV are on the same network and that the connection is stable.
Let me know if you need anymore assistance.
