Battery drain
(Topic created on: 17-10-2021 12:24 PM)
Stonecold65
Pioneer
Phone died overnight, it's never done that before anyone else having battery drain problems?
8 REPLIES 8
G0UDG
Voyager
No problem here with battery drain
DianDD
Helping Hand
Check the battery stats and see what's the app with exceed battery usage
F19AJW
Voyager
Yes had battery drain sin e been on beta.
I found Microsoft Authenticator which I use regularly for work sign ins for various account as using the highest drain. It has got better since marking the app to close after use, but level still not where I am used to.
May get better with next update as there have been plenty of reports.
And I donteport my issues to the beta seem with error reporting.
NewAge
Navigator
Yes, I have noticed this too. It drains very fast since updated to Beta 12
Alfsdad
Voyager
I have had no issues wity battery draining. I have the same settings in use as was with Android 11 UI3.1
BB4UK
No problems with battery
kennyboy57
my battery drains faster than old software.
MartynaK
Beta Moderator
Beta Moderator
@Stonecold65,
I've also noticed some battery problems on my device 😬.
Please, report the issue via the Samsung Members app attaching log files :hand-with-index-and-middle-fingers-crossed:.
