Battery Issues
(Topic created on: 23-10-2021 05:54 PM)
Barrie-Wilson
Navigator
I decided to give the beta a try on my s21 ultra. Has anyone experienced battery draining? In the space of 2 and a half hours it has fallen more than 30% with just general use (scrolling through Facebook and sending messages). Never had this problem before the update so taking it it's the beta that's causing it?
12 REPLIES 12
Tpg21
Yeah I noticed aswell. Draining battery very quick just the normal use.
nowdeleted
Big Cheese
Turn off the adaptive brightness and turn the brightness down by 25% or more if you feel confident. Also dark mode helps.
Barrie-Wilson
Navigator
Yeah I've already done this on the device before installing the beta
Cloud355
Are you on beta 2 or 3? Beta 2 my battery was dying raidly, beta 3 has improved it quite a bit for me
Darrenwalsh
Voyager
I would imagine so
JLasenberg
Pioneer
Was listening music on the way for around 2 hours plus phone slightly heated up and battery was down from 95 to 45. Was surprised
romanlinley
My 21 ultra lost 40% after update just in my bag at work this afternoon
adamlee
Black Belt
Because of CameraService_worker again. Recently fixed on android 11 October patch, they've now brought the bug back with android 12. 😭😭😭😭Screenshot_20211023-195854_GSam Battery Monitor.jpg
MM3301
Pathfinder
I've had the opposite for the normal galaxy s21. I feel like the battery has got better with the update
