04-01-2023 09:27 AM - last edited 04-01-2023 09:29 AM
I open my edge panel and choose a contact to call from the direct call panel. It automatically opens Viber, if I remove Viber it works normally. I can't find any settings on Viber or in Direct Call Panel to fix this issue.
Viber takes over the Phone Call.
Though using the "People Edge" works normally.
any fixes for that issue?
21-08-2025 06:20 PM
Try People panel, not Direct Call panel
Saturday
You are a life saver!! I had searched for a solution to this since eternity!!
Thank you so much!
Saturday
Go to your home screen and add widgets section and add the direct dial widget (in attached screenshot) and try making a call from it. It'll ask you the default app, select it and you are done!
