When I try to place a call using direct call from the edge panel it opens Viber App?
(Topic created on: 04-01-2023 09:27 AM)
ManalFF
I open my edge panel and choose a contact to call from the direct call panel. It automatically opens Viber, if I remove Viber it works normally. I can't find any settings on Viber or in Direct Call Panel to fix this issue.
Viber takes over the Phone Call.
Though using the "People Edge" works normally.
any fixes for that issue?
32 REPLIES 32
Hus83
Again i have the sam problem, out of the blue
Victoria G
Try to delete Viber and when you reinstall it do not allow call management. I hope it workes.
Mikham
Go to
 settings, applications, manage applications. You then need to scroll down to viber and press clear default. When you will try to dial out you will then choose your phone regular caller icon as default.
Hus83
Can you be more specific. I enter viber in setting apps, but therse no clear default. Only clear cache
ManalFF
Nothing fixed this issue with me since then, except uninstalling viber totally. Whenever I need viber I reinstall it and so on.
Nothing seems to fix this issue with me while viber is installed.
Mikham
Just follow the sequence as it is written, settings, applications, manage applications.  Then find viber under manage applications, then press clear default
Charmed84
I have this wierd problem too. I changed phones (the same phone Note 20 ultra both) and on old one never had this proble. New phone - nothing works. Please fix this!
Mikham
Try to go to settings then apps, then scroll down to phone, click on phone and make sure under calling app the word phone appears. I hope this will help.
mharvin_sm09
Turn off Viber Call in Viber app settings..
Then Force Stop the Viber App in settings..
Try to call again using phone call or in contact or through messaging app
mharvin_sm09
