When I try to place a call using direct call from the edge panel it opens Viber App?
(Topic created on: 04-01-2023 09:27 AM)
ManalFF
I open my edge panel and choose a contact to call from the direct call panel. It automatically opens Viber, if I remove Viber it works normally. I can't find any settings on Viber or in Direct Call Panel to fix this issue.
Viber takes over the Phone Call.
Though using the "People Edge" works normally.
any fixes for that issue?
30 REPLIES 30
Hus83
Doesent change anything
Members_a0VpiWs
The same for me on new flip 5. On previous flip 4 everything works well, the same settings. Anyone found any solution? Thank You
ManalFF
Unfortunately, still same issue. I need to uninstall Viber. And then install it again when needed and so on. 😢
Joeylene Berja
Joeylene Berja
karaganchev
Found solution for this!
Just add direct call shortcut on your home screen with some contact of yours. Then when you click it will ask you which app to use, then select dialer and tick to always use it.
This is solving the direct call edge panel bug, hope it helps you.
Members_zaImVUk
Hi
Could You give more specific sequence how can be done it, please?
V6h4
I have the same issue with my recently bought samsung galaxy s24 plus
ManalFF
Thank you for your solution, I am using both options and they are both available. But I need Samsung to fix this issue
ManalFF
Hi I really hope they can fix this issue you can find some workarounds on the replies here. But the bug is still there.
