28-01-2021 01:58 PM - last edited 28-01-2021 04:52 PM
We’ve been noticing a lot of conversation in our Community about power, battery and charging on the S21 family devices, so wanted to consolidate a quick guide for you to help you with your questions!
What data/power cable comes with the S21, S21+ or S21 Ultra?
You’ll get a USB-C to USB-C cable in the box with your S21, S21+ or S21 Ultra that you can use for wired data transfer or to power your phone with a Samsung power adapter (sold separately).
What power adapter (power brick/travel adapter/charger block) should be used with the S21, S21+ or S21 Ultra?
We recommend that you use a 25W USB-C Samsung Power Adapter (that block that goes into the mains) with your S21 device. This will allow you to benefit from Super-Fast charging with your phone to keep you going. You can use a compatible Samsung charger from a previous device, or can buy the adapter separately (as you know, it does not come in the box).
Do the S21, S21+ or S21 Ultra support wireless charging?
You can use Qi wireless charging to power your device with a wireless charger (sold separately) or can turn your new phone into a wireless charging pad to charge other compatible devices by using the Wireless Powershare feature.
Helpful power, battery and charging specifications
Galaxy S21 |
Galaxy S21+ |
Galaxy S21 Ultra |
Battery capacity |
4,000 mAh |
4,800mAh |
5,000mAh |
Data/power cable (included in the box) |
USB-C to USB-C cable |
Power adapter (sold separately) |
USB-C power adapter |
Wireless Charging |
Yes, using Qi wireless charging standard |
Wireless PowerShare |
Yes |
Wired Charging Speed |
Super-Fast Charging with Samsung charger that supports this (25W USB-C) |
Compatible Samsung power adaptor (sold separately) |
Up to 25W |
Will my 45W charger work with the S21 devices?
A Samsung 45W USB-C power charger will charge the S21 super fast using up to 25W. To achieve super-fast charging speeds it must be connected usb-c to usb-c.
The charger defines the maximum amount of power that it can draw but the device will define how much is actually drawn to the device.
Is there a 45W charger available for the S21 series?
With the enhancements to our charging technology, we no longer see the benefit of 45W chargers and are able to deliver super-fast charging with 25W chargers.
Do you have more power, battery or charging questions, please post in the below!
01-10-2021 01:44 PM
My s21 ultra 5g is a bit of a let down, i wish i still had my s9.
I cant charge it and use wired headphones simultaneously.
When its charging i cant use the keyboard, it jumps all over and is very eratic. Same if i try a game when charging, no control.
The camera seems to be a downgrade, poor quality, no slow motion capture etc.
After a decade my next phone probably wont be a samsung,
27-10-2021 04:13 PM
I'm sorry but this is a complete own goal. I admire the commitment to be green but you can't tell everyone to use previous plugs when your cables are incompatible. This stinks of a company trying to make more money under the auspices of being environmentally friendly.
No thank you, the handset is being returned and I'll go with a different company.
07-11-2021 03:49 PM
