No ring tone for incoming calls
(Topic created on: 09-01-2025 10:56 AM)
rsh123
I've lost ring tones, other notifications working fine. I think it's since I last installed an update. Checked all the obvious, do o need another update? What can I do?
4 REPLIES 4
Fiona26
Samsung Members Star ★
Have you checked all volume settings? Made sure ring tone is turned up?. You can give the device a restart or a reboot. See if that fixes the issue.
rsh123
Yes done all that. It's like there are no ringtones to select from. Restarted several times, checked do not disturb or call forwarding isn't on.
BandOfBrothers
Samsung Members Star ★★
A broadsworded option is >
  • Clear Cache Files from the phone's System Partition Section  > https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/ You may need to insert your earphones or hook upto a powered On Laptop or use a Tv's USB Port to access the Clear Partition Section. This may help with lag or stutters as this clears the phone of old/unused or broken cache files.There is also a Repair Apps option in the Menu System too { Possibly excluding the s²⁴ Series of phone's }
I hope this helps @rsh123
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
xSteveuk
Mastermind
Hi,
If you don't have any ringtones to select from on your Samsung phone, you can try these steps:
Check your sound modes
Go to Settings > Sounds and vibrations > Sound modes and make sure you've selected a mode that includes ringtones.
Check your mute settings
Go to Settings > Accessibility > Hearing enhancements and make sure Mute all sounds is turned off.
Check your Airplane mode
Swipe down from the top of the screen with two fingers to open the Quick settings panel and make sure Airplane mode is turned off.
Check your Do not Disturb settings
Swipe down from the top of the screen with two fingers to open the Quick settings panel and check your Do not Disturb settings.
Restart your phone
Swipe down from the top of the screen with two fingers, tap the Power icon, tap Restart, and then tap Restart again to confirm.
Update your software
Go to Settings > Software update and download and install any available updates.
Clear your cache
Go to Settings > Apps > Phone/Samsung Dialer > Storage > Clear cache.
Boot your phone in Safe Mode
Press and hold the Power button, tap and hold Restart, and then tap Safe mode when it appears.
