Low battery sound
(Topic created on: 26-10-2019 05:40 PM)
Tim6897
Guys,
My low battery sound had just stopped working, I've not changed any settings etc and can't  find out how to reactivate, can anyone help ? Tia
AndrewL
@Tim6897: Can you try going to Settings > Apps > Tap the 3 dots in the top right > Show System Apps > System UI (green P thumbnail) > Notifications > Tap on 'Battery' > Notification Style (choose Sound or Sound and Pop-Up) > Sound (Select an option from the list). Hope this helps.
5 REPLIES 5
AndrewL
Tim6897
Thanks for your help
Ganeshken
Very Accurate solution
sadasulo
This doesn't work anymore. There's no System Apps option under the 3 dots now.
AndrewL
@sadasulo: On more recent Android versions, please head to Settings > Apps > Tap the 3 lines to the right of 'Your apps' > Show system apps (toggle this on) > OK > System UI > Notifications > Allow sound and vibration.
