Washing Machine - Residue, Stiff clothes and whites not as clean as they shoud be
(Topic created on: 12-01-2020 08:52 PM)
Markp17
Have a two month old WW80J5555FX washing machine. clothes are coming out of machine stiff and with a residue on clothes. Whites also appear to not be washing clean and come out dirty. Have previously used washing power and normal softner as used on previous machines (including a Samsung) with no issues. Have tried washing machine tablets instead and still have same problem. My daughter who has a similar age samsung has washed some of the clothes and the problem including the dirty whites all dissapear when washed in her machine.  has anyone experianced any similar issues ??
5 REPLIES 5
AndrewL
@Markp17: Following a completed cycle, have you noticed if there's still washing powder in the detergent drawer? What cycle(s) is the issue occurring on?
To troubleshoot the issue in the meantime please perform an Eco Drum Clean by following the steps below.
1. Press Power to turn on the washing machine.
2. Turn the Cycle Selector to select ECO DRUM CLEAN.
3. Press Start/Pause.
Markp17
Andrew Thank you for your reply.    We have done the eco clean a number of times. Their was no washing pwder in the detergent draw, but we did have some inside the door rubber. We have now changed to washing tablets and the clothes are still giving the same issues.
KManji
I am having this same issue. When the clothes are air dried in the house or outside they dry stiff. When in the dryer they are fine. What is causing this. I have done eco drum clean too..my machine has the auto dispense.
andy_in_ireland
Troubleshooter
Hi-
Try upping the dose of the fabric softener - go into setting and increase 'dose per wash'  and change the other settings of the machine for water type - use a setting for hard water.
and try a different fabric conditioner.
try increasing the rinses on your washing , maybe residue detergent soap is left in clothes and makes them stiff when dried .
i still find though tumble dried are much better than dried on line for softness, the warm air must relax the fibres better .
good luck.
KManji
Thank you I will try this.
