Washer Dryer - vent hose?
(Topic created on: 12-07-2023 11:26 AM)
Liplip
I'm thinking of getting a Samsung washer dryer but I live in a rented property, and my landlord is concerned because there's nowhere to put a venting hose and he's worried about humidity.
Are there any washer dryers that I can just hook up to where my current washing machine is, that don't need a vent hose?
3 REPLIES 3
Pugs1957
SuperStar
If you opt for a machine with a condenser drier you don't need a hole in the wall as the condensation is caught in a tank for you to empty.
keith30
Legend
Have you looked at an condenser dryer, these type don't use a venting hose and now on the market you can get heat pump ones but are more costly. I have a Hoover condenser dyer and the water from your clothes goes into a water tank which you just empty after each use. Not sure what dryers Samsung do throu.
andy_in_ireland
Troubleshooter
washer dryers dont have a 4" exhaust venting pipe in the drying cycle of these, the 'condensation' from the clothes as they are drying is pumped out down the drain  from the pump on the washer dryer
