Side by side fridge (RH58K6598SL/EG) is leaking water inside the fridge area
(Topic created on: 03-01-2022 05:05 PM)
DirkBogaert
Hi Samsung,
So far, I am very happy with my Side-by-side fridge (RH58K6598SL/EG). Unfortunately, since a couple of days, I have the following problem. Every day, I have to remove water from the bottom of the fridge. It seems to be coming out of an area that sits behind the vegetable boxes at the bottom of the Fridge area (not the freezer area). I took a picture which is attached.
Any idea what may be the cause?
Thanks!
3 REPLIES 3
xSteveuk
Mastermind
Hi,
This page maybe helpful
What should I do if I suspect my Samsung fridge/freezer is leaking water?
https://www.samsung.com/uk/support/home-appliances/what-should-i-do-if-i-suspect-my-samsung-fridge-f...
How old is the fridge
Do still have warranty On it
You try contacting support
https://www.samsung.com/uk/support/contact/
DirkBogaert
Hi (Steve I suppose),
I tried all what was provided as potential solutions. Unfortunately, none of them seems to have solved the issue. There is still a daily build up of some (very clean) water inside the fridge area :-(.
Any other ideas/suggestions? Anyone?
Many thanks!
xSteveuk
Mastermind
Hi,
It's could be a clogged defrost drain. The refrigerator's automatic defrost faulty that's causing the build up of water
Perhaps try support
If you still have warranty
